emu compare table
EMU PRO-16 EMU PRO-8 EMU BLACK EMU CLASSIC
Engine type: Port Injection
Direct Injection (requires GDI Driver
Port Injection
Port Injection Port Injection
Operating temperature range: AECQ100 GRADE1
(-40 to +125˚C)
AECQ100 GRADE1
(-40 to +125˚C)
AECQ100 GRADE2
(-40 to +105˚C)
AECQ100 GRADE2
(-40 to +105˚C)
Water and dust resistant: IP 65 IP 65 IP60 IP60
Connector: 4x AMP Superseal (120 pins) 3x AMP Superseal (96 pins) 2x FCI automotive (63 pins) 2x FCI automotive (48 pins)
Injectors: 16x peak and hold (8A) 8x peak and hold (8A) Up to 8x HiZ (5A)* 6 HiZ (5A)
Ignition outputs: 12x active or 10x passive coils (15A)
(software selectable)
8x active or passive coils (15A)
6x active or passive coils (7A)(software selectable) 6x active or passive coils (7A)(software selectable)
Auxiliary outputs: 16x low-side (5A)
(protected, short circuit and open
circuit diagnostic, current control)
12x low-side (5A)
Up to 6x low-side (5A)*
1x dedicated WBO heater (5A)
(protected)
6x low-side (5A)
(protected)
H-bridges: 4x full H-bridge (8A)
(protected, diagnostic)
3x full H-bridge (8A)
2x full H-bridge (7A)
(protected)
2x full H-bridge (0.8A)
(protected)
+5V sources: 2x 500 milliamps (two independent) 2x 500 milliamps (two independent) 1x 500 milliamps 1x 500 milliamps
Analog inputs: 20x 12 bits
with software selectable
pullups/pulldowns
8×16 bits high precision with software
selectable pullups/pulldowns
(single or differential)
16x 12 bits
pullups/pulldowns
4×16 bits high precision with software
9x 10 bits, with software selectable pullups/pulldowns
2x EGT dedicated inputs
(K-Type thermocouple)
7×10 bits
2x EGT dedicated inputs (K-Type thermocouple)
Digital inputs: 10x inputs for VR or HALL
sensors (software selectable)
8x inputs for VR or HALL
3x inputs for VR or HALL sensors (software selectable) 3x switch to ground inputs 3x inputs for VR or HALL sensors (software selectable)
Direct injection: Up to 8x injectors
Requires external module
Up to 8x injectors
No No
Lambda controllers: 2x LSU 4.9 2x LSU 4.9 1x LSU 4.9 or LSU 4.2 1x LSU 4.2
DBW controllers: 2x 2x 1x Requires external module
VVT controllers: 4x 4x 2x 2x
Knock sensors: 2 inputs 2 inputs 2 inputs 2 inputs
CAN-bus: 2x CAN 2.0 A/B 2x CAN 2.0 A/B 1x CAN 2.0 A/B Requires external module
LIN-bus: 1x 1x No No
Realtime PC data-logging: Yes Yes Yes Yes
External data-logging: To USB flash drive To USB flash drive Requires external module Requires external module
Data-logging frequency: Up to 500 Hz Up to 500 Hz 25Hz 20Hz
PC connectivity: CAN** CAN** USB-C USB-A
All features unlocked: Yes Yes Yes Yes
Free software updates: Yes Yes Yes Yes
* Two auxiliary outputs can be used as injector outputs ** Requires CAN adapter (ECUMASTER USBtoCAN, Peak CAN or Kvaser)
