Chevrolet Camaro Gen6 LT1/LT4
This base map is tailored for use with the Camaro Gen6 LT1/LT4 EMU PRO-16 PnP Kit.
It supports all Camaro Gen6 configurations, including LT1 and LT4 engines and all transmission variants. You select your configuration when loading the base map.
The vehicle operates at near OEM-level functionality. However, performance driving requires per-vehicle calibration adjustments.
The base map controls the following:
- GDI injectors
- GDI high-pressure fuel pump
- All OEM sensor calibrations
- Transmission torque maps (including torque reduction and throttle blips)
- Alternator control
- Air conditioning control
- Electronic throttle (drive-by-wire)
- VVT solenoid control
- Fuel pump
- Coolant fan
- Knock control
- Ignition maps
- Fuel maps
Unsupported features:
- Cylinder deactivation
- Skip shift
Modifications:
- Exhaust system without catalytic converters
- Two LSU 4.9 sensors installed in the downpipes (included in the PnP Kit)
Setup Details:
Tuned Power Output (calibrated on a dyno):
LT1 engine:
- Power: 450 HP
- Torque: 620 Nm
LT4 engine:
- Power: 680 HP
- Torque: 940 Nm
Downloads
Full Description and Specifications
How to Load This Base Map
1. Download EMU PRO software version 261.2.2 or later:
https://www.ecumaster.com/products/emu-pro/
2. Open the Base Map Loader (File / Load Base Map…)
3. Select the base map for your car, then choose your engine and transmission configuration
For more details, see:
How to Load Base Maps in EMU PRO
⚠ Before loading to your ECU:
This base map is a starting point for tuning. It is not guaranteed to work correctly out of the box and may require adjustments to fit your particular setup.
Verify that all assigned outputs match your wiring. In the software, go to Tools / Assigned outputs and Tools / Assigned inputs. If the assignments do not match, do not load the map to your ECU. Adjust the outputs as necessary before proceeding.
