EMU PRO base map for LT1 Gen V Engine
GM LT1 Gen V Engine
This configuration applies only to the LT1 engine itself and does not include any vehicle-specific settings.
Be sure to configure all additional components such as the low-pressure fuel pump, cooling fans, starter, and other auxiliary systems.
Stock engine (no internal modifications)
Exhaust system without catalytic converters
Two LSU 4.9 sensors installed in the downpipes (OEM oxygen sensors are not supported)
The attached map controls the following:
– GDI injectors
– GDI high-pressure fuel pump
– Alternator control using a PWM signal
– Control of the oil pressure solenoid (with the control deactivated, maximum oil pressure will be delivered)
– Electronic throttle controlled via the SENT protocol
– Fuel rail pressure sensor with SENT protocol (3 pin sensor)
– VVTi solenoid control
Setup Details:
EMU PRO-8 + GDI Driver
Description
Base Map
GDI Driver configuration
Scope
Inputs and outputs assignment
High-pressure Fuel Rail Sensor Types Technote
These baseline maps provide a starting point for tuning and are designed for specific engines. They are not guaranteed to work correctly out of the box and may require adjustments to fit your particular setup. Always treat these maps as a foundation to build upon and make further refinements as needed.
This base map was created using EMU PRO version 225.x.
You can download this version from our archive page: https://www.ecumaster.com/older-versions/
Tuned Power Output:
– Power: 500 HP
– Torque: 670 Nm
– Tuned on a dyno.
