ECUMaster EMU Pro!
Get information about latest versions of software
Wuniek
ECUMaster EMU Pro!
Post by Wuniek » Thu Nov 12, 2015 12:51 am
are there any pre order options ?
https://www.facebook.com/ECUMasterUSA/p ... 8200617246
Scheduled for release in the third quarter of 2016, the ECUMaster EMU Pro is the next generation high performance engine management system from ECUMaster!
Pricing information will be announced at a later date.
The EMU Pro features the following capabilities:
Supports up to 8 cylinder engines in sequential operation, and 12 cylinder engines in semi-sequential operation
User definable current control for injector output channels (for low impedance injectors)
Advanced data acquisition system with up to 512 Hz logging per channel and 2 GB internal memory
Built in 3-axis accelerometer
Advanced paddle shift and gear change cut strategies
Support for VANOS, VVTi and other variable cam systems (control for up to 4 cams)
Sophisticated Drive By Wire support for 1 or 2 throttles
Advanced fueling algorithm based on resultant engine volumetric efficiency
Built in dual-channel wideband oxygen sensor control (for Bosch LSU 4.2 or 4.9 sensors)
User-definable output channel assignments
3D tables resolution up to 32x32
Engine protection functions
Free firmware updates
Waterproof housing (IP67 standard)
8 Injector channels (high or low impedance)
8 Ignition channels (up to 15A, smart or passive coils)
16 Auxiliary outputs (6A)
2 H-Bridges (up to 6.4A)
2 CAN BUS Channels (CAN 2.0B)
1 Serial Output
16 Analog inputs
2 EGT Inputs
2 Knock sensor channels
5 Trigger inputs (1 crank, 4 cam, Hall or VR)
4 Wheel speed inputs (hall or VR)
1 Flex Fuel Input
1 Turbo shaft speed input
chris72
Re: ECUMaster EMU Pro!
Post by chris72 » Fri Nov 13, 2015 6:38 pm
I could be a beta tester on a turbo hayabusa :D
Looks like a very nice piece of kit.. keep up the good work
redmkiv
Post by redmkiv » Thu Nov 19, 2015 12:06 pm
I hope it works with AT Transmission, for me the killer feature...
bbabich
Post by bbabich » Sun Jul 17, 2016 6:51 pm
Any update on this one? Is it any closer to being released?
Marc Knoll
Post by Marc Knoll » Tue Aug 09, 2016 8:02 pm
Hey ECUMasters any News about the EMU Pro ???? Time to sell this we are waiting :mrgreen:
R-tune
Post by R-tune » Mon Aug 15, 2016 9:44 pm
I'm also very interested! Any news? :)
Post by PSI-Motor » Tue Aug 16, 2016 10:19 pm
Still under development.
Labrenz Racing
Post by Labrenz Racing » Mon Sep 26, 2016 9:40 pm
Any update on release ?? I'm about to purchase Emu and I don't want the pro to come out couple weeks later ....
shrek69
Post by shrek69 » Wed Oct 12, 2016 9:25 pm
is there an other Homepage like
www.ecumaster.com
