ECU nie może się połączyć
Posted: Wed May 06, 2015 10:03 pm
by mikyyy
Cześć wszystkim. Nadal mam problemy z DET3 . Mam BMW E36 m52b25 silnika. Podłączyłemurządzenie mówi system BMW. jeśli mogę umieścić kołki używane do masy urządzenia nie włączyć . W rzeczywistościchwilę Trzymam je luzem. Innym problemem ,komputer uważa , że jestdołączony moduł sterujący , ale gdy otwieram klienta lubimplant paliwa wydaje się, żeurządzenie nie jest podłączone . możesz mi pomóc? dziękuję. Przepraszam, jeśli mój polski nie jest doskonały, ale sąwłoski , który korzysta z Google translate
Re: ECU nie może się połączyć
Posted: Wed May 20, 2015 7:43 pm
by Kisielisodd
please, translate from italian to english directly in google, because i (and others probably to ) don't understand your issue :(
Posted: Sun May 24, 2015 3:17 pm
by mikyyy
Hello everyone . I still have problems with DET3 . I have a bmw e36 engine m52b25 . I connected the DET3 as the diagram, but the client and fuel implant , below left , appears "can not connect" . I tried to change PC , uninstall and reinstall , change USB cable , but nothing . in the settings of the computer is connected to the DET3 . the red light is on and you turn on the machine also . can you help me? thanks
Posted: Sun May 24, 2015 8:25 pm
by Wuniek
is your computer recognizing device ?
did you instaled usb drivers?
http://ecumaster.com/en/download
Posted: Mon May 25, 2015 10:48 pm
by mikyyy
yes , the USB ports see the DET3 and I installed all the download site . I do not understand what the problem is
Posted: Tue May 26, 2015 8:43 pm
by Wuniek
is device is new? if not did it works on other setup (car) ?
did you maybe flash it to change from piggy back to fuel implant? are using proper client for mode that your device is flashed?
my only idea for you is to connect only +12 GND and then try once again to connect if this doesn't work it will be probably hardware problem with your device
mikyyy wrote:yes , the USB ports see the DET3 and I installed all the download site . I do not understand what the problem is
Posted: Wed May 27, 2015 9:29 pm
by mikyyy
the device is new. I downloaded the client from the download site and the cd rom and on both computers that I tried is not working. I do not know about the flash to change from piggyback to fuel implant mode. then you say to try to connect pins 1 and 12 to a battery and try to see if device connect to PC ?
Posted: Thu May 28, 2015 8:29 am
by Wuniek
if it is new then it is flashed as piggy back try install "Client for Windows 1.32" http://www.ecumaster.com/testVersions.html connect only power and check, also dont use any car charger to power supply laptop because it will create loops on the ground and cause problems with proper sensors reading
you can also try install newer USB driver but i dont think this is the issue http://www.ftdichip.com/Drivers/D2XX.htm ( 2.12.00 WHQL Certified )
mikyyy wrote:the device is new. I downloaded the client from the download site and the cd rom and on both computers that I tried is not working. I do not know about the flash to change from piggyback to fuel implant mode. then you say to try to connect pins 1 and 12 to a battery and try to see if device connect to PC ?
Posted: Fri May 29, 2015 10:11 pm
by mikyyy
wont run! i tried another pc and same problem of other pc. windows see new item on usb but the software don't see det3
