trigger request fiat 1.8..
ESRA Car performance
Post by ESRA Car performance » Wed Feb 24, 2016 10:07 pm
Im new in the EMU world.
tryring to get a fiat 1.8 16v to run..
just wire it in.
setting up the ecu now.
can some one please look at the trigger settings i shoul use?
cheers
the rotation is the wrong way on in the pic!...
signal.
cam trigger
crank trigger
Re: trigger request fiat 1.8..
Post by ESRA Car performance » Sat Feb 27, 2016 11:25 pm
No one?
I was thinking...
2e tooth..
65 degrees.
roquete
Post by roquete » Sun Feb 28, 2016 2:31 am
that is a weird pattern, maybe the gurus from ecumaster will have another idea, but i would use a simple 36-1 or 60-2 trigger wheel.
cant you fit like a pulley from fiat punto 1.1? it already have a 60-2 trigger wheel on it
Post by ESRA Car performance » Sun Feb 28, 2016 7:12 am
It's the same as a Subaru 6 tooth.
And that one is supported by the emu :)
Just need to know what to put in as the trigger
Post by ESRA Car performance » Mon Feb 29, 2016 4:10 pm
No one else?
Post by Jadzwin » Tue Mar 01, 2016 1:34 am
Is it Fiat Stilo ?
It looks the same as subaru.
So I would give a try the following settings:
Post by ESRA Car performance » Sat Mar 05, 2016 12:35 pm
car is a Barchetta
this is the scope i got now.
and the settings
scope_201635_1129.emuscp
(93Bytes)Downloaded 93 times
Post by Jadzwin » Sat Mar 05, 2016 8:29 pm
Please try my settings. Should work. Of course check the spark with the timing lamp.
Post by ESRA Car performance » Sun Mar 06, 2016 12:39 am
The car does not have timing marks.
Have to make my own.
Post by ESRA Car performance » Sat Mar 19, 2016 10:07 am
I can not get her to fire up..
Timing is not in the same place every time.
Seems like its using a different start position?
Post by ESRA Car performance » Sat Mar 19, 2016 10:09 am
Btw..
The rotation is the picture is the good way
Post by ESRA Car performance » Sat Mar 19, 2016 11:20 am
this is the scope.
with the subaru 6 tooth settings i get a lot less triggers.
plus in the manual it say that it does not work with cam sinc..
so should i go group injection and wasted spark?
6tooth.emuscp
(111Bytes)Downloaded 89 times
fiat scope.emuscp
(261Bytes)Downloaded 110 times
Post by Jadzwin » Sat Mar 19, 2016 3:31 pm
The scope looks ok. This signal is converted to 2 tooth per revolution.
It works with cam sync. I sent you configuration.
You have to use cam sync otherwise it will not work.
Post by ESRA Car performance » Sun Mar 20, 2016 10:53 am
Oke thanks.
Car is a
Fiat Barchetta
1.8 16v.
360cc injectors.
Turbo
Can you please send it to
R.akkermans@esra-carperformance.com
Post by ESRA Car performance » Wed Mar 23, 2016 1:27 pm
Hello Sir.
Did you send the file already?
Desperate to try.
Post by ESRA Car performance » Fri Mar 25, 2016 10:01 pm
Want o test it tomorrow morning.
Really need that file :(
