Hi is there a way to disable the EMU's internal IAT and ECT Pullups?
I am running the EMU in parallel. It looks like I could reassign Analouge inputs for IAT and ECT but I loose two inputs in doing so.
Disable IAT & ECT Pullup
Re: Disable IAT & ECT Pullup
There is no possiblity to deactivate pullups by software.
You can connect sesnors directly to EMU and use fixed resistors to emulate sensors for OEM ECU
I have it setup and working well right now using the Analog inputs - I will see if I end up needing more inputs or not. It seems to be working well at the moment although I'm yet to do a proper road test. My hope is that the OEM ECU is going to continue to shift the transmission as it did before
