Ecu State at Cranking Problem
VR6-Lumpi
Post by VR6-Lumpi » Mon Mar 07, 2016 1:25 pm
I have a problem at cranking.
When I start my car then comes the ECU State is inactive although rpm detected.
Sometimes the ecu State is cranking when I start the car.
Why the controller does not recognize it, I did start?
Here a log.
6:10 to 6:50 there is good to see.
Last year all was ok.
Then i`ve change my cams.
And this year the car start normal, but next day it dosn´t start ans make this Problem.
What can make this Problem?
20160204_1205.emulog
(218.85KiB)Downloaded 109 times
DT-GT42
Re: Ecu State at Cranking Problem
Post by DT-GT42 » Mon Mar 07, 2016 11:54 pm
post please your emu file
Jan32
Post by Jan32 » Tue Mar 08, 2016 7:56 am
Is it in full sequentiell mode or wasted spark. I would test wasted spark, because i think after your changes at the cams the secondary trigger is now between two cycles and switches around between the right one and the false one.
For first test you can move to wasted spark and if this works fine, you have to change the position of the secondary trigger!
VR6-Lumpi
Post by VR6-Lumpi » Tue Mar 08, 2016 9:45 am
Is it in full sequentiell mode.
I will check this in wasted spark and check the cam position.
Vr6T.emu
(99.09KiB)Downloaded 116 times
Jan32
Post by Jan32 » Tue Mar 08, 2016 10:07 am
In your config is the secondary trigger tooth on falling edge, you can also test it on rising edge.
VR6-Lumpi
Post by VR6-Lumpi » Tue Mar 08, 2016 10:14 am
This makes no difference.
With a clear emu file on the ecu it is working in cranking Mode.
In wasted spark mode it dosn`t work with my primary trigger Setup.
Jan32
Post by Jan32 » Tue Mar 08, 2016 11:07 am
Then please make a scope while cranking.
VR6-Lumpi
Post by VR6-Lumpi » Tue Mar 08, 2016 11:19 am
So here is the trigger scope.
I have check the cam position this is ok.
The hall sensor from cam is at the same position like before i change the cams.
When i start in wasted spark mode the ignition angle goes as i cranking mode but the injection time is 0ms and the injectors make once splash.
scope_201628_101.emuscp
(313Bytes)Downloaded 118 times
Jan32
Post by Jan32 » Tue Mar 08, 2016 12:34 pm
i found some faltly parameters. Under engine start, crancing threshold is 200 and has to be 400 and engine stall rev limit is 200 an has to be lower, try 60.
In your scope i can see, that your cabeling is wrong, you have to change the +/- of your primary trigger VR sensor.
VR6-Lumpi
Post by VR6-Lumpi » Tue Mar 08, 2016 1:12 pm
The problem I have also just found.
What makes you think this is the VR sensor connected incorrectly?
Post by Jadzwin » Tue Mar 08, 2016 1:32 pm
Your engine stall revs are set to 200!!!
That is the reason. The EMU use this value to knows if the RPM are high enough to crank.
So you need over 200RPM to shift into cranking state.
Set this value to 50-60...
Jan32
Post by Jan32 » Tue Mar 08, 2016 1:48 pm
I can see it in your scope! The first signal after the gap has another time gap as the others.
VR6-Lumpi
Post by VR6-Lumpi » Thu Mar 10, 2016 12:50 pm
I have switch den cable. And now the car dosn´t start and the trigger signal is the same.
scope_2016210_1131.emuscp
Scope with switch cable
(514Bytes)Downloaded 92 times
old Scope
(313Bytes)Downloaded 95 times
Post by Jadzwin » Thu Mar 10, 2016 1:19 pm
Send two scopes with falling and rising edge..
And fix this settings!!
VR6-Lumpi
Post by VR6-Lumpi » Fri Mar 11, 2016 12:35 pm
The other problem is already solved.
Now is the first trigger ok.
Which setup for the second trigger is the right one?
The motor starts with rising and falling
scope falling.emuscp
Second trigger falling
(274Bytes)Downloaded 84 times
Scoppe rising.emuscp
Second trigger rising
(239Bytes)Downloaded 110 times
Jan32
Post by Jan32 » Fri Mar 11, 2016 2:05 pm
You have to use these settings.
VR6-Lumpi
Post by VR6-Lumpi » Sat Mar 12, 2016 12:17 pm
Thank you for the fast support :D
