And now i would like to use the two of EMU ECU for my Projekt. One EMU for Cyl. 1-6 and another one for Cyl 7-12. The Idle run, throttle bodies are controlled by original EML from 850Csi. So i want to use the EMU only for Injection and Ignition. So i have some questions about possible configs:
is it possible
a) to use only one Crankshaft-Sensor and send the signal to another emu?
b) to use only one camshaft sensor for sync of all cylinders?
c) to use only one CLT-Sensor and send the signal to another emu?
d) the same for IAT-Sensor?
e) to use for each Bank an own distributor for ignition with EMU (also a coil + distributor for cyl 1-6 and a coil + distributor for cyl 7-12)
If i use for sending of data between the emus the serial port, can i connect the bluetooth module too?
Thank You Guys, sorry for my English, i´m a russian living in Germany
If you want some more pics:
http://www.bmw-syndikat.de/bmwsyndikatf ... -_E36.html
