ANDROID DASH - VERSION 2.1.0 - Available in Google Play
It's just a different type of sensor/controller and I don't know why it has different reading.
Best lean power is 13.1 on the Bosch LSU 4.2 using Innovate or EMU -they read the same as you can see
If I was doing a quick tune using the dyno wideband I'd just tune to 12.8 as a target
Re: ANDROID DASH - VERSION 2.1.0 - Available in Google Play
I have compared EMU vs Bosch Motorsport lambda and they are EXACTLY the same
It's not a Bosch Motorsport and its a few years old
Would Android Dash working well as a RPM gauge? I mean it can connect and running automatically and how long is the delay time.
I suffer from RPM gauge delay a lot, on stock gauge and low end ebay gauge.
If this android dash working well like a LCD data logger It will save a lot money!
i found new bug .,. when i make rec. with android dash.
my MAP make some bug and show 254...
this is my log with android dash.
pepifebles
I have Issues with Any channels. Afr its ok but lambda channel always show 0. 1.1 emu version.
The fun starts now
I have issues connecting to the bluetooth module. I have to try 5-6 times, sometimes it will not connect at all, from both my phone and my tablet. It is very annoying.
is there a bug with the fuel pressure delta gauge???
or am i doing something wrong?
it seems to be in the wrong units and stuck on 100Kpa
I also am unable to to get propper logging via the APP. I have done several logs of various lengths but when opened in EMU Client I only get 5 or so seconds of data logged.derOJ wrote:I habe problems with logging.
I made 4 Loge with the app but Windows client cannot read them.
Two of the logs Werke at least 2 Minuten long.
But client only shows 10 seconds or so....
- Copy of EMULog_20160723_070032.log
- added .log file extension for upload
- (50.72KiB)Downloaded 147 times
Display mode with 4x2 or 4x3 grid would be great. Maybe something similar as it is on VemsDisplay.
Once more, it is very annoying to have to hard-reset the application every time to use it. When are you going to fix this?
is there ever going to be an iphone app? or is there an obd2 scanner app that will work with reading data from the emu?
Would be great to include an internal GPS speedometer for people who can't run speedos. (My setup with CD009 in an S14 - 350z speed sensor is located in their differentials) Other than that, great app!
I'm having issues with logging and also log content. Sometimes the logs don't record at all and when they do half of the channels are missing please help!
I also had a random Check Engine light illuminate for high exhaust gas temperature (65187C) but I have no probe fitted
Anyone else having the same problem?Astroboy wrote:I'm having issues with logging and also log content. Sometimes the logs don't record at all and when they do half of the channels are missing please help!
I could really do with some assistance on this. I now can't log at all. The app shows as recording but there are no logs. I am also now getting random 'check engine' lights flashing up
ESRA Car performance
can this connect thru usb already?
