Hi, anybody can tell me any idea to set vehicle speed?. Mine its very bad, 3º gear to 7100rpm show 104km/h and really correct speed its about 155km/h
Add my log
3SGTE Speed (km/h)
pepifebles
The fun starts now
Re: 3SGTE Speed (km/h)
Go to Sensors/VSS and Gearbox.
sensor type Hall
Falling
frequency divider set to 1
enable pull-up
Then set Speed Ratio until vehicle speedo (Or your GPS) and EMU log match. I run about .852 to get my speed to match MPH. If you have an electronically driven speedometer in your Toyota (most 93+), check the capacitors in the cluster. when they fail and leak, it will cause incorrect speed reading.
sensor type Hall
Falling
enable pull-up
mine is set to 1.5 but its an import with kmh clocks and im displaying in mph . how acurate it is is another thing , i dont think its far off
pepifebles
1994 celica ST205. Then I have to play with frequencie?? Stock dash run ok compare with GPS.
One more time, thanks Scott and anybody.
The fun starts now
I have '92 MR2 JDM and using divider of 1,469, seemed to be closest I could get with a laggy 1Hz mobile phone GPS.
Some of the MR2 speed sensors are NOISY!! and virtually unusable, but the wiring is getting pretty old, so that's to be expected.
I just set the cruise control, to give my phone GPS time to get "accurate" then dial in the speed ratio, or adjust it on the dyno.
as i said mine is set at 1.5 , was at the strip yesterday , terminal was 132 , logs say 140 so not far off .
pepifebles
Thanks gays. Problem solved. Have set to 1,508 and run perfect.
The fun starts now
