No Ignition at VW 16V Turbo with BERU ZSE 033 Coils
can anyone tell me how I can use ZSE 033 Coils on a VW 16V Turbo engine? The Coils need an positive signal for Ignition. When I remember right the EMU gives an negative signal out.
Have I to use us pullup like these: http://www.megasquirt.de/msforum/viewtopic.php?t=4472 or does I have to buy other coils?
Thanks for your help!
Greeting,
Marty
Greeting,
Marty
Re: No Ignition at VW 16V Turbo with BERU ZSE 033 Coils
If you use EMU, you just simply select Coils with or without amplifier ................. The VWgroup COPs are :smart: so they have bulit in amplifier.
The BERU ZSE 033 Coils are with built in amplifier, they are used in the VWgroup.
1: Permanent plus (+6 up to +16V)
2: Permanent minus
3: Signal for ignition 5V
4: Minus for signal
The coils doesnt fire when I connect it to pin 3.
When I give permanent 5V to pin 3 and the EMU to pin 4 it does also not fire.
The ECUMASTER have to give out an 5V then the coils will be fire. But what I have to do or to buy? The Megasquirt have the option to change it to an 5V signal. The EMU also? Where?
2: Permanent minus
4: Minus for signal
You can't have permanent 12v, it must be switched.
The EMU doesn't have any problems running these coils.
the emu has problems running these coils.
the wiring is correct, we need a positive (5-14V) signal for the coils.
it is possible to switch the ignition outputs from negative to positive, yes or no?
Just select active coils
Where can I select them?
What coils should I use? Did you have an other type of coils in the same size like BERU ZSE 033 Coils?Jadzwin wrote:Just select active coils
EMU is able to work with any coil.
This Beru coils work for sure.
Do you connect one coil to one EMU output ? Or you paired them ?
one coil, one output.
Black 16 and Grey 8,16,9
And what is your ignition otuput config ?
Could you send log file ? Is you trigger system correctly synchronised ?
Seems like i couldnt upload any file, can i send you a email with the log file?
You can use attach function from forum (for emu files) or send it to tech(at)ecumaster.com
i think we solved it. we had trouble with the primary trigger. now we have a lot of sparks.
thanks for your help everybody
