RUNNING E85 ENRICH MAP BY %
im looking to run E85 this week end, and i was wondering if there was a way to select the entire fuel map and add like 30% fuel? i didnt see anything in the hot keys. i know its possible in other standalone ecu, and im just wondering if the EMU has it also
Re: RUNNING E85 ENRICH MAP BY %
Go to injector trim and type in 135-140% on all injector outputs.
or multiply all map values by 1,3 - in manual for 2d/3d tables, you have description how to use * / + - calculations in all 2d/3d tables.
im running the lsu 4.2 ive changed the fuel type to ethanol 85%. will the 3D AFR table need to be changed also or will that automatically convert Stoich to 14.5 AFR regardless of fuel type?
never mind i see the option to change my 3D table to lambda thanks!
