3sgte tacho multiplier
mmg
Post by mmg » Sun Jun 12, 2016 8:33 am
Hi, I am using the 3s-gte plug&play adapter
The dashboard tacho shows half of the real RPM
Looking at outputs->tacho output, I see "output: none" and chaging the multiplier there does not have any effect
Where should I look?
BoostMonkey
Re: 3sgte tacho multiplier
Post by BoostMonkey » Mon Jun 13, 2016 5:32 am
hello in which the car 3sgte is installed? Mr2?
mmg
Post by mmg » Mon Jun 13, 2016 9:04 pm
Hello Celica Gt4
BoostMonkey
Post by BoostMonkey » Fri Jun 17, 2016 5:30 am
Remove the 40K resistor in the tachometer, to a piece of wire
mmg
Post by mmg » Sat Jun 18, 2016 11:47 am
thanks BoostMonkey!
mmg
Post by mmg » Fri Jul 15, 2016 5:26 pm
Hi I replaced the resistor with a wire and nothing changed, any ideas?
ren
Post by ren » Fri Jul 15, 2016 6:01 pm
Use the specific tacho output - aux 4 maybe?
Post by RHD » Sun Jul 17, 2016 4:15 am
OUTPUTS/ Tacho Output/ RPM multiplier... change the value until it reads correct
ATS_Scott
Post by ATS_Scott » Fri Jul 22, 2016 9:52 pm
The stock tach gets it's signal from the stock igniter, not the EMU (unless you have replaced the ignition system with aftermarket). I'd replace the capacitors in the tach first, and see if that solves your issue. While it's apart replace the speedo caps as well if it's electronic speedo.
Welshman
Post by Welshman » Sat Jul 23, 2016 5:32 pm
i had COP now i have just fitted some AEM coils , my tach works fine and for the life of me a cant remember how i did it lol
mmg
Post by mmg » Mon Aug 29, 2016 9:40 pm
Hi any ideas anyone? I am replacing my steering wheel so good moment to fiddle with the tacho again due to easier access
A friend told me the tacho is just a voltometer which means I need just to calculate an appropriate resitor.. Correct?
ATS_Scott
Post by ATS_Scott » Tue Aug 30, 2016 3:25 pm
mmg wrote:Hi any ideas anyone? I am replacing my steering wheel so good moment to fiddle with the tacho again due to easier access
Did you check capacitors yet? 99% chance that is your only problem...
