Hi everyone,
I need help with wiring up the EMU to the throttle. any help would be appreciated.
2JZ GTE VVTi Throttel wiring to emu
Re: 2JZ GTE VVTi Throttel wiring to emu
HI
I believe this is quite old and odd throttle and has bit strange settings first you have a clutch to engage motor to throttle
(cable on throttle is conencted to pedal position sensor and mechanically only opening throttle on the end of the stroke plus) you have a stepper motor with 6 wires..
so you need 4 outputs for stepper 1 for clutch and something to drive a motor overall quite confusing setup and "eating" your outputs what we used to do we locked mechanically throttle witch throttle cable and we retaining stepper motor for idle control ....
Do you have more info/spec for this modification? How many outputs did you use for the stepper motor (idle control)? How about the throttle wiring?gregpe wrote:what we used to do we locked mechanically throttle witch throttle cable and we retaining stepper motor for idle control ....
idle stepper need 4 stepper outputs all wiring on help section on ecumaster sowftware..
