gear cut trouble
cer
gear cut trouble
Post by cer » Tue May 03, 2016 6:28 pm
hello,
i have a little trouble on a Norma F20 running with a 2,0 Honda V-Tec engine. The engine works fine but when we use the gear cut for sequentiell shifting , there is a rev limmit at 5000rpm. I only had to disable the funktion an the engine goes up to his limit. I think there is a mistake in my adjustment, but i dont know wich parameter is for this mistake.
WHPZach
Re: gear cut trouble
Post by WHPZach » Tue May 03, 2016 7:03 pm
Post your current map and a log of the problem. Data is king.
cer
Post by cer » Tue May 03, 2016 8:00 pm
at the moment the car is by his owner. and he isnt allowed to have a look into the mapping. so i cant give any log data. i testet the gear cut on dyno at nearly 4000 rpm and all works perfekt. but on the last race the owner explain the problems to me. and now i had to find a solution very quickly.
Post by Jadzwin » Thu May 05, 2016 3:50 pm
send the gear cut configuration here and log
cer
Post by cer » Fri Jul 15, 2016 12:25 pm
Hello again,
this setting i try, and have a limiter at 5000rpm. with the flat shift setting it works
norma flat shift.PNG (9.62KiB)Viewed 3775 times
cer
Post by cer » Mon Aug 01, 2016 4:33 pm
her is the log of last race. you can see that the gearcut switch make no signal, but there is a spark cut. what can i do? if i cut the signal cable of the switch then it works without spark cut, but of course you can`t put in the next gear.
Post by Jadzwin » Mon Aug 01, 2016 9:35 pm
Please attach here the log and you base calibration
