hi everyone ,
just trying to do a base map on my zetec with toyota coils , wired direct from the ecu . i have found the dwell times but need info on fire order and settings on the coil dwell wizard , single fire? amp ?
i have mine wire on the coil
pin1 12v +
pin2
pin3 signal from ecu 1: g8 2: g16 3:g9 4:b16
pin4 ground
does this look correct ? any help will be great
denso / toyota coil settings
Re: denso / toyota coil settings
i used info from here , worked ok http://www.sq-engineering.com/tech-arti ... info-guide
