Has anyone used EMU with direct injection?
What hi voltage external drivers are available that could be used?
running direct injection engines??
Re: running direct injection engines??
Not possible.. Direct Injection is much more complicated than just controlling high pressure injectors. You need also control HP fuel pump and take into consideration some other factors.
mmm... ok
might be something to look into now! because almost all manufacturers will use this technology soon if they are not using it already.
Motech have a dedicated m1 version for DI and Haltech are working on it right now, Im sure lots of others are doing the same.
We do it also
Another ECU manufacturer does have a step up box that will allow DI injector driving. There are also a couple of OEM parts that do this.RHD wrote:Has anyone used EMU with direct injection?
