Bugs and Feature reqests
- jt-performance
- Contact:
Yes I know. It is hust an idea.
Ecumaster the Netherlands
Re: Bugs and Feature reqests
For knock control:
I would like "Knock Sensor 1 Value" and Knock Sensor 2 Value" in channels list. Or, better yet, channels for each individual cylinder. Also, gain adjustment for each cylinder.
For EMU client, can we PLEASE have ability to add as many tabs as we want and be able to name them??!! I want to set up a tab for each function and there simply are not enough to do it. It is SO slow deleting stuff and adding when it's time to go from tuning fuel to idle to start to etc...... It's also annoying that all my desktops have changed when I plug into a different EMU.
Please set it up so there is a "desktops" file extension that we can select and load into the EMU client. I want to spend time setting this up how I want ONCE and not have to navigate the menu tree during tuning. 7 tabs won't do that! I've got 45 set up in another EMS program. 15 of them are visible tabs and 30 are in a drop down list for easy access when needed.
Hi Kurt!
In software 1.1 you can save your layout template(s) to file and open them.
For next version we would like to option to add/remove/rename desktops.
For knock sensor we will see what we can do
That's great news! Saw there were some issues with 1.1 and hadn't yet tried it out. I added some feedback in the other thread.
Further suggestion: Channels and options are "grouped" in predefined windows. It would save a lot of screen space if we could simply put the specific channels we want in a single window, and same for options. Also, the save, open, and help bar at the top of each table takes up pace. Can you add a button on each table to allow us to hide this bar?
Yep that is doable
Jadzvin did you read my post about electronic wastegate?
Will there ever possible that EMU communicate with the PC via BT ??
We can expect an update to android app?
On Xperia Z1 (A 4.4.4) does not work correctly ... please answer, thank you ...
Is this normal? Not displayed correctly ... how can I log? You can only change units on the gauges, but the style gauges can not be changed, only digital (digital / clock / chart).
It doesn't look correct. You can try Vems tune and AIM protocol.
We are looking for new programmer to continue developement of Android application.
Yep, I'm so really sorry but actually we do not plan to add support of electronic wastegate0martin0 wrote:Jadzvin did you read my post about electronic wastegate?
YES!!Jadzwin wrote:Hi!
I hope to find a programmer
It's not about bug, but it could be modified in "Load Wizard Bins",
to act decimal numbers?
My pressure senzor for oil and fuel work 0,5V - 4,5V linearly.
Fixed, will be released with RC1 tommorow
Angelo S38
Just a short question, should you be able to communicate and programm the EMU using just the USB cable and a computer or does it need 12v as well?
Needs 12v and gounds
Good job.
A communication is possible with a PC through bluetooth?
In the future?
In the future?
Angelo S38
As expected, Thank you.PSI-Motor wrote:Needs 12v and gounds
nemitom wrote:Good job.
In the future?
i wouldnt mind that my laptops and win8 tablet have bluetooth so emu software and dash would be good
It yes.
Or android app that can handle modifications ..... such as MSdroid or DTAdroid
But I understand that it may not be used by anyone ...
When i change the x Axix on IAT or CLT Sensor it change it to IAT and CLT Sensors, not only the Sensor what i want.
When i change the X Axix on Oil Oress. or Oil-temp or Fuel Press. or Fuel Level it change it to all, not what i want.
The y axis for Fuelpressure is a litlle bit to small.
