89 supra 7mgte not going past 5000 rpm
Mpohoriles
So as the title says my car will not rev past 5000 rpm the problem started once I put the standalone in two months ago and It is starting to get very frustrating I have try many things and it seems nothing is working in even tried putting the ecu in my buddy's car to see if it was something with my car but it had the same problem can someone please help me
- mp log 10.emulog
- (267.51KiB)Downloaded 128 times
- mike 7mgte map.emu
- (101.16KiB)Downloaded 120 times
Re: 89 supra 7mgte not going past 5000 rpm
I think you run to lean or to fat. I can´t see any lambda value in your log so that is the point for what you sould looking for. And please switch your ego correction off when your lambda is not working.
Mpohoriles
Yea I forgot to plug back in the wide band I'm going to do that then take another log thank u for look
Mpohoriles
here is the log with the wideband hooked up
- log 10.emulog
- (181KiB)Downloaded 117 times
i think your issue is ignition related,
too big spark plug gap - adjust gap to 0,6mm
too small dwell - increase 0.5ms
poor coil + - measure with osciloscope when engine running on coil + if voltage drops down
too rich mixture which spark can´t go thru - decrease VE
-afr is jumping from 12 to sky , but injector duty cycle is stable around 30%. 30% of 550cc whi is roughly 165HP thats realy enugh fuel for free reving engine. for double sure check your fuel pressure if it realy is stable. but more probable scenario is that mixture is not ignited and uncombusted air passing o2 sensor is causing lean reading
br MM
br MM
EDIT: wrong idea !!! toyota multiplex igniter needs diferent setup (credit to Denny from ecumaster usa) following text will be right only if you connect coils directly to emu with no igniter
ignition outputs seems to be messed up
i think that you have 3 coils conected to outputs 1,2 and 4 (dont know why, i will go 123 but ok)
A - coil (FOR 1+6 cyl) wired to out1
B - coil (FOR 3+4 cyl) wired to out4
C - coil (FOR 2+5 cyl) wired to out2
firing ordeer cylinder: 153624
firing order coils: ACBACB
firing order outputs: 124124
1+4 or 1+2 make no sense because it is used if u have coils on plugs and you want to fire them "wasted spark"
so please set your emu to output order like that :
1 event - output 1
2 event - output 2
3 event - output 4
4 event - output 1
5 event - output 2
6 event - output 4
br Martin
1 event - output 1
2 event - output 2
3 event - output 4
4 event - output 1
5 event - output 2
6 event - output 4
br Martin
allso fueling squirt tvice per cycle checkbox should be checked
aaah now i figured it out! it cannot work.. your dwell time is 4.2ms and you fire output1 every event, it mean 3times per revolution, 5000rpm is 83revs per second, one second is 1000ms, 1000ms divided by 83 revolutions is 12ms per revolution,12 divided by 3 events per rev is 4ms. so your dwell can be max 4ms at 5000. so your ign. out 1 is saturated , it is active all the time , duty cycle is 100% - you have to decrease your dwell time!
Mpohoriles
Lowered the dwell time and it now free revs to 6300 thank u
