JZX100 1JZ VVTi Crank and Cam Settings
bwicknick
Post by bwicknick » Sun Dec 11, 2016 2:35 am
Can someone send me a screenshot or a base map of how to set the correlation between cam and crank and what settings to use to achieve crank sync. I am coming from AEM so I am used to the wizard doing this job for me. I did some searching and I haven't found anything specific. Thank you.
It is the standard 36-2 crank wheel and the 3 tooth cam trigger with equal spacing.
0martin0
Re: JZX100 1JZ VVTi Crank and Cam Settings
Post by 0martin0 » Sun Dec 11, 2016 10:19 am
I don think that 3equal teeth on cam will work, on my car i will grind off 2 of them and use only one
Post by PSI-Motor » Sun Dec 11, 2016 12:55 pm
Of course it works with 3 cam teeth.
0martin0
Post by 0martin0 » Sun Dec 11, 2016 1:25 pm
I will belive in that if they will not be equaly spaced... but of course i can be wrong...
Post by Karel » Sun Dec 11, 2016 2:43 pm
This works for me.
0martin0
Post by 0martin0 » Sun Dec 11, 2016 3:06 pm
Shame on me... i missed that one in secondary trigger setup....
bwicknick
Post by bwicknick » Tue Dec 13, 2016 12:30 am
Thanks Karel. Exactly what I was looking for. I've noticed you are very helpful in other posts. Thanks for all your help for everyone.
