I'm coming to EMU from the AEM world, and my first install is on my single turbo 2jz mk3 supra. The car was running e85 on the AEM (so it's what is in the tank currently).
I'm getting close to turning the key, and trying to wrap my head around the the fuel calculation formula. Base on the fact that a flex fuel sender can be used to blend two VE maps, as well as AFR target maps, it would appear that if I wanted to make the startup map e85 friendly, I would simply add VE (probably to the tune of around 30%, and tune it from there).
I just want to confirm I understand this right. I can see it would definitely work, even though it doesn't seem like the fuel type actually changes the volumetric efficiency. It's really no different then in AEM world simply telling the injectors to put more fuel in the engine at a particular load point. I just want to make sure there isn't some setting I'm overlooking that tells the ecu the energy density of the fuel or something.
Cheers!
