Can someone share base map for Subaru EJ20 GC8 MY98 ? Or at least idle control and cold start-up maps? It takes more then 10 minutes to start when cold....
You can send me PM if You don't want Your map to be Public!
Best regards, Janko
subaru EJ20 BASE MAP
Re: subaru EJ20 BASE MAP
Post the calibration you are using at the moment - I reckon your temperature compensations will be off, and after 10 minutes, with the heat you have managed to make, you are getting closer to the required fuel/air/ign setting.
hi, i have a basemap from my ej20 my97 with 440cc injectors. coldstart could be better but it works for starting the engine.
Hi, i sent You PM!philsinc wrote:hi, i have a basemap from my ej20 my97 with 440cc injectors. coldstart could be better but it works for starting the engine.
I have problems with crank sensor calibration.
The car doesnt startup the most of our tries.
We have connect the ingition and injectors in full sequential way.
Do you have a startup calibration to help us?
Thank you in advance
Hi!philsinc wrote:hi, i have a basemap from my ej20 my97 with 440cc injectors. coldstart could be better but it works for starting the engine.
Would You be so kind and share the map on PW.
Just finished wiring loom on cg8 my99, time to get started.
