bmw m20 no sync
hello i have wired up the emu and it connects to the ecu, but it wont sync, says no sync. using 60-2 trigger, any ideas? still running distributor but with and MSD ignition amplifier. but it wont sync at all. i have no clue whats wrong. not using the original "camsync" from the plugwires
Re: bmw m20 no sync
When i try to scope it shows nothing at all. No readings
Re: bmw m20 no sync
Activate scope under primary trigger, press arrow on the scope page that says "get scope data" if it doesn't show anything you messed up your wiring.
Re: bmw m20 no sync
Even tried with a brand new hallsensor, still no scope, its only pin 7 + 18 and 5v it want? How can it not work
Re: bmw m20 no sync
Problem solved. Engine starts now!
