Bugs and Feature reqests
2wheels1man
Re: Bugs and Feature reqests
Post by 2wheels1man » Thu Mar 23, 2017 7:42 pm
Did you have time to check it please?
Jadzwin wrote:I will check it, it should work
2wheels1man wrote:Please, please fix the Lambda always 0.00 problem when importing log from serial logger. It's been like a year, me and some other people wrote about this multiple times.
When you import log, android dash or keelog serial ghost, lambda shown is always 0.00. I know it's working because the logger logs data going to my dash, which displays lambda no problem.
It gonna be some small silly mistake in the import function.
EDIT: i'm on version 1.183
derOJ
Post by derOJ » Mon Apr 03, 2017 9:06 pm
Hi.
Maybe you can bring support for High resolution displays :)
Mine is a 3200x1800 display with no chance to change it...most of programms can handle this, but not EMU Client.
I don't know wether it's a small change in you prog?
It looks this way :
high resolution problem
Corvin
Post by Corvin » Thu Apr 06, 2017 1:14 pm
derOJ wrote:Hi.
It looks this way :
Wild guess 1:
Your windows uses a zoom for texts, apps and other elements of > 100%.
Solution 1:
Set it to 100%. Unfortunately this is a very common problem for many applications.
Wild guess 2:
You are running the client on a MacOS with the hypervisor "Parallels" for emulating Windows.
Solution 2:
play around a bit with the parallels options for screen rezising and zoom. Chose the option that passes the genuine Mac resolution through to Windows.
Corvin
Post by Corvin » Thu Apr 06, 2017 1:15 pm
feature idea:
Integrate a shiftlight in your Android App.
derOJ
Post by derOJ » Fri Apr 07, 2017 8:47 am
Corvin wrote:
derOJ wrote:Hi.
It looks this way :
Wild guess 1:
Solution 1:
Thanks for help. I use Windows 10. I have a set 250% zoom. But when I put it to 100% everything get smaller of course. Then I cannot even read the tables :mrgreen: :mrgreen:
It is a matter of luxus I guess ;) I won't have to change settings every day. For this I use the windows build in "magnifying glass"
forhome
Post by forhome » Sat Apr 08, 2017 5:09 pm
The check engine light for knock output is not accurate. it's been coming on even the knock sensor value is below the engine noise threshold.
Post by Karel » Wed Apr 12, 2017 1:07 pm
Please think more about what you are writing. The datalog is written may be 25/s but the engine can spark 50-100 times per second. Also the "knock" (voltage over trigger) can happen many times on single working cycle of each cilinder. So it can easy happen, that your engine will knock, but the log will not show it.
Again, please do not make any fast judgements, if you are not sure about what you are talking.
Thank you.
forhome
Post by forhome » Thu Apr 13, 2017 12:17 am
It's too sensitive would be a better choice of word I suppose............
Post by Karel » Thu Apr 13, 2017 9:20 am
forhome wrote:It's too sensitive would be a better choice of word I suppose............
"Too sensitive" ??? Are you joking? So you would prefer knock detection system that is inacurate, slow, and deaf as a post ? :D
roquete
Post by roquete » Thu Apr 13, 2017 5:45 pm
I think is talking about the fact that even at 1.92v engine noise is set and 0.80v of sensor value, the ecu triggers a Knock check error code even if knock level and knock ignition event remains 0, thats what i can see at is log image.
forhome
Post by forhome » Thu Apr 13, 2017 6:35 pm
Thank you.
I don't think he even saw the picture or get the point of my post.............
forhome
Post by forhome » Thu Apr 13, 2017 6:48 pm
I don't know why Karel keeps having his head up his ass with all his useless comments. I am just reporting a possible bug I have discovered. There's no need to be hostile.....................
Post by Karel » Thu Apr 13, 2017 9:08 pm
forhome wrote:I don't know why Karel keeps having his head up his ass with all his useless comments. I am just reporting a possible bug I have discovered. There's no need to be hostile.....................
If you start talking like that ...... are you sure, your "Check engine" light comes up because knock ? Did you looked into the log for reason why the light was on ? There are other reasons for triggering the Check engine ...
EDIT: Post an log file, calibration file and i will look into it...
gesch
Post by gesch » Wed Apr 19, 2017 12:53 pm
hi
can't connect the device to the computer,no connection!!
the other ecumaster unit connects without problems
I can send you the test??where it is possible to fix it??
ECU
Paulo11
Post by Paulo11 » Sat Apr 29, 2017 8:50 am
You tryed it with the same cable ? Maybe that is the problem. Or you can have broken USB conector like my friend(smashed terminal when it was engaged).
2wheels1man
Post by 2wheels1man » Sun Apr 30, 2017 7:00 pm
Hi.
One thing that would help me a lot.
Oil pressure engine protection, instead of shutting the ignition down, have an output on a simple light that would light up if the pressure falls below acceptable point.
Having a FWD race car, when the oil pressure cut happens in a turn it will result in a spin. Which can be very dangerous, if there are cars behind me.
Of course I know that oil pressure should never drop, but well...
Now I have the oil pressure cut configured on a very low pressure, so that it only cuts, if the oil pump fails.
I have to chceck the logs after the race to see, if the pressure dropped.
With a simple light the driver would know if it flashed.
ALSO: Please fix lambda always 0.00 in imported log problem. Please :(
Thank you
samvel
Post by samvel » Sun Apr 30, 2017 7:46 pm
2wheels1man wrote:Hi.
Thank you
Just use parametric output.
2wheels1man
Post by 2wheels1man » Sun Apr 30, 2017 9:08 pm
With parametric output I can't set different pressures for different RPMs.
So it would be pretty much useless.
JZX100EMU
Post by JZX100EMU » Mon May 01, 2017 2:54 pm
Feature request 01:
An error-dependent P and I term, in order to reduce overshoot and settling time, without sacrificing speed
Feature request 02:
In te log one can see the "Acc. Enrichment (%)". I think it would be helpful to be able to see how this would break down in terms of Acc Enrichment (dTPS, TPS, RPM, CLT). The same goes for "Dec."
pitt_92
exp 1.187 exp1
Post by pitt_92 » Wed May 03, 2017 11:37 am
Hello ,
i run firmware 1.187 exp1 on my device to corrige autotune bug ( 1.184 exp1 ) , but engine turn poor ( afr 14.9 when target is 13.8 at idle )
bug or bad sensor ? ( rcal okay its my zeitronix sensor )
