TPS config question
Mikey1982
TPS config question
Post by Mikey1982 » Sun Apr 23, 2017 5:02 pm
I have followed wiring diagrams for my car but wanted to double check, basically the tps shows 5v when closed and goes lower when opening, I have configured the EMU so its 0% when closed and 100% when WOT but just checking if this is ok as the voltage seems to be backwards as i thought it would be 0v closed and 5v open but the wiring all seems right, cheers
BRT
Re: TPS config question
Post by BRT » Mon Apr 24, 2017 9:03 am
You have to change the two parameters below then, also.
www.Beth-Rennsporttechnik.de
roquete
Post by roquete » Mon Apr 24, 2017 11:45 am
your wiring, gnd and 5v in tps is wrong just reverse it but if you have configured it that way its ok to leave it.
Mikey1982
Post by Mikey1982 » Wed Apr 26, 2017 10:59 am
Awesome, I have reversed the earth and 5v now so its reading 0 -5 instead of 5 - 0 and configured accordingly, not sure if it makes any difference but seems like the right way to do it,
Cheers for the help
