Bosch lsu 4.2 or 4.9
Yanisxae86
Post by Yanisxae86 » Mon Jan 30, 2017 10:48 pm
Hello, im currently busy with doing a 4age 20v swap in my ae86. Im planning to buy an EMU Ecumaster and it has a build in lambda controller for the lsu 4.2. The problem is i want to use an LSU 4.9 with gauge but is this possible?
Thanks for the help.
Yanis
Gpetrou
Re: Bosch lsu 4.2 or 4.9
Post by Gpetrou » Mon Jan 30, 2017 11:34 pm
Hi, if you want 4.9 sensor you must use an external controller and use it's analog output to connect it to an analog input on EMU or just use 4.2 sensor and wire it directly to EMU. You will find all the details in the manual.
Yanisxae86
Post by Yanisxae86 » Mon Jan 30, 2017 11:42 pm
Thanks for the quick reply but im pretty new in this and im not completely following. What wire do i need to use as input for the EMU?
Gpetrou
Post by Gpetrou » Tue Jan 31, 2017 12:25 pm
The picture shows 4.2 sensor... Anyway in aem 30-4100 (lsu 4.2) and 30-4110 (lsu 4.9) the white wire is analog output and you have to connect it to an analog in 1-4 on EMU.
Yanisxae86
Post by Yanisxae86 » Tue Jan 31, 2017 2:08 pm
Thanks a lot! :D but i see there are a few kind of sensors lik the 30-4110 and 30-0300 x-series. Whats the difference and wich one to take?
roquete
Post by roquete » Tue Jan 31, 2017 2:36 pm
4.9 is a better and cheaper sensor, aem and innovate are upgrading to 4.9, any of them will do if you want to keep the meter, any of them as got 0-5v output for connecting to emu analog in.
Post by RHD » Thu Feb 02, 2017 2:24 pm
emu BLACK also accepts the LSU 4.9 directly
Schlander
Post by Schlander » Tue May 09, 2017 3:17 pm
Will the normal EMU ecu accept the LSU 4,9 directly?
rockyboist
Post by rockyboist » Wed May 10, 2017 4:33 am
Possible. I have the same setup Innovate MTX-L and wired the analog out to one of the available analog ins of the EMU. Then you go to Oxygen sensor setup and set it there especially the voltage mappings, issue I only have is that I cannot put the exact voltage figures for minimum and maximum because of the value limitation EMU has for its minimum and maximum. So one more step is to do is to connect the Innovate software to your controller then change the voltage mappings on innovate itself to match the EMU. I dont have a serial cable so I havent done it yet, what I did was to somewhat lean out the Lambda targets until I get the AFR I want on the gauge. If I dont, it runs very rich 10ish on pump gas.
pric
Post by pric » Wed May 10, 2017 12:28 pm
Schlander wrote:Will the normal EMU ecu accept the LSU 4,9 directly?
No.
Mercedes C280 M104 Turbo
Schlander
Post by Schlander » Wed May 10, 2017 4:03 pm
rockyboist wrote:Possible. I have the same setup Innovate MTX-L and wired the analog out to one of the available analog ins of the EMU. Then you go to Oxygen sensor setup and set it there especially the voltage mappings, issue I only have is that I cannot put the exact voltage figures for minimum and maximum because of the value limitation EMU has for its minimum and maximum. So one more step is to do is to connect the Innovate software to your controller then change the voltage mappings on innovate itself to match the EMU. I dont have a serial cable so I havent done it yet, what I did was to somewhat lean out the Lambda targets until I get the AFR I want on the gauge. If I dont, it runs very rich 10ish on pump gas.
So it is possible as long as your write the specs in the EMU for the sensor?
rockyboist
Post by rockyboist » Thu May 11, 2017 12:09 am
^ Sorry that was intended for the original post.
