Autotune
i don`t have different version.. i try everything.. i use only VE 1 for now i try with + - but nothink..Finally I typed them by hand ( and for stopping autotune i need close na re-open my client or i can`t make any changes in VE table)
Re: Autotune
I found the autotune changes often do not stay permanent! so I need to save the adjusted tune and reload by open project and then make permanent.
Re: Autotune
Please try the version 1.160. The Autotune apply bug should be fixed
Re: Autotune
can't get the autotune to work, after i press OK with the settings the autotune window wouldn't open
Re: Autotune
I haven't tried Autotune yet but am planning to. How long does the engine have to be held at a certain load point in order for Autotune to work?
Re: Autotune
Several minutes of drive under diferent load is enough
Re: Autotune
Some Problem here. when I click autotune in the Tab you can change the Rpm min Max, tps, etc... But when click Ok nothing happened. I am running the Beta 1.184driftkids wrote:can't get the autotune to work, after i press OK with the settings the autotune window wouldn't open
Re: Autotune
Did you follow steps from help ?
rockyboist
Re: Autotune
Wow Autotune seems great. I'll try it this week. Thanks for the tips.
Re: Autotune
What you mean? Help in the emu client?Jadzwin wrote:Did you follow steps from help ?
Well I can not start autotune in the taps on the left. Only on the Top / Tools but after the Pop-up menu nothing happens.
Re: Autotune
maybe you already have a open autotune window somewere,Silas wrote:What you mean? Help in the emu client?Jadzwin wrote:Did you follow steps from help ?
try this:
close all windows with ctrl-shift-C then try again with tools / autotune / ok
Re: Autotune
I am also having the same issue. I can open the autotune from the tools drop down menu. log-Autotune does not open the window. Once I click ok, the window closes, and thats it. nothing else happens. Ive also closed out all the open windows.
Re: Autotune
Re: Autotune
Re: Autotune
What software / firmware version do you use ?
Re: Autotune
I got the same results at soon as i press ok the window closes and that's it..
Version 1.188
Version 1.188
Re: Autotune
Can i use autotune in alphaN fueling ?
Re: Autotune
Yes is it possible
selfdestroyer
Re: Autotune
How works realtime autotune? Activation key or what?Change log for version 1.110 EXP1
EMU Client
• Maximization of windows fixed
• Real time autotune
• Tune display
• Flickering of windows fixed (?)
