ASk for 3SGTE basic settings
packall
Post by packall » Tue Dec 02, 2014 4:11 pm
Does anybody work on 3SGTE with Ecumaster Unit?
Im thinking about using Audi COP.
Engine will be from ST205 ( JDM vers. ), we will make own wiring ( original wiring is damaged ).
Is tehre possibility to download basic settings for first run ? ( after idle runnig it will be tuned on dyno ).
Our second project is 1UZFE engine, so if somebody has any experiences with this negine, COP's and EMu please let me know.
Re: ASk for 3SGTE basic settings
Post by Jadzwin » Tue Dec 02, 2014 5:18 pm
Please find our ST205 base map and how to connect EMU
It is not a problem to connect COPs in your case.
3sgte.pdf
EMU Connection
(82.82KiB)Downloaded 176 times
3sgte_ST205.emu
3SGTE BASE MAP
(62.18KiB)Downloaded 190 times
packall
Post by packall » Tue Dec 02, 2014 6:20 pm
Many thanks, I go to check then :)
Any basemaps for 1UZ ? :)
Welshman
Post by Welshman » Mon Feb 02, 2015 1:13 am
would it be possible someone has a startup/base map for a 3sgte with st215 crank and cam senser ,with COP , 1000cc hks top feed injectors .
or just setup for primary ignition and cam please .
ATS_Scott
Post by ATS_Scott » Mon Feb 02, 2015 10:06 pm
This is what I have been using for Gen4 3sgte. Should be same or similar for 3sge Beams as well.
Welshman
Post by Welshman » Tue Feb 03, 2015 12:02 am
yes will be the same , its basically a st215 but has a st205 block atm .
cheers :)
felipeandrest205
Post by felipeandrest205 » Sun Feb 08, 2015 8:32 pm
The basemap of the 3sgte would be compatible with DET3?
Post by Jadzwin » Mon Feb 09, 2015 1:51 pm
No it is different device.
DET3 is piggy back, EMU is advanced stand alone ECU.
