Hello everyone, currently working on putting a 3sge beams into a TE72 corolla, got everything wired up and I can get the motor to fire over but sounds like it isn't firing on all cylinders or is firing at the wrong time, which is weird because timing checks out at 10 degrees when I have it locked.
I'm guessing I have a mistake in my crank/cam trigger settings, since that is one of the few things I'm not confident on.
I'm currently using the intake cam for reset.
Does anyone have a beams basemap I could look at to confirm my setup before I start digging into checking for mechanical issues?
3sge Beams - Basemap Help
Re: 3sge Beams - Basemap Help
For reference I am running the following trigger settings.
Primary:
Type: 2 missing teeth
Teeth: 36
Trigger Angle: 67
First tooth: 15
Secondary (Intake cam):
Ive played around with a few different options, but am currently running missing tooth.
Primary:
Teeth: 36
Trigger Angle: 67
First tooth: 15
pepifebles
Yeah Beams has a 36 tooth crank trigger and a 4-1 cam trigger on both intake and exhaust.
I was really hoping ATS_Scott could chime in on this since they sell plug and play 3sge beams ecu's.
i run a st215 ign setup , same as a beams iirc
pic attached , the dwell times are for my aem smart coils so you best double check for your coils .
try this if you still need a map.
- beams-3sge.emub
- (119.64KiB)Downloaded 131 times
