Celica GT4 3SGTE ST185 won't start with PnP module
mika
Post by mika » Wed Aug 09, 2017 7:37 pm
Hello.
I've here a Celica GT4 and bought a PnP module for it. I just asked an module with an extra harness for use it with coils instead of the distribuitor, run an IAT sensor and to eliminate MAF.
In the beggining I couldn't control fuel pump relay because I didn't knew that I needed to configure switches inside the module. I've configured it and now I can control it. But I can't control main relay and I think that because of it I haven't any fuel being injected.
I have the car ready to be started and I'm having this problem now.
I've readed a very similar topic on this forum but there isn't any solution for this.
Best regards
rockyboist
Re: Celica GT4 3SGTE ST185 won't start with PnP module
Post by rockyboist » Thu Aug 10, 2017 12:18 am
Where did you get your PnP from? You should upload your map and logs so people will be able to help you better. I can compare your base map to mine to check the differences in settings.
