Base Map for 4AGE 20v Blacktop
rockyboist
Post by rockyboist » Thu Aug 10, 2017 12:20 am
Anyone knows where I can get this? Or has someone plugged and tuned this motor before with the EMU?
Re: Base Map for 4AGE 20v Blacktop
Post by RHD » Fri Aug 11, 2017 12:31 pm
you really done need a "base" map the ecu will read all the oem sensors and im sure the trigger configuration is commonly known so you can just build your own "base map" in about 20 minutes, reading the user manual is a great start
as far as i know there are 24 cam teeth as primary trigger so that translates to multitooth primary with 12 teeth (if it were on the crank, same as a lot of toyota engines) and the secondary or camsync is 1 tooth so you can just play with ignition offsets and first tooth setting until it fires and refine id down with a timing light.
rockyboist
Post by rockyboist » Mon Aug 14, 2017 2:07 pm
Thanks RHD. Im more into the settings and values to put in the sensors, injectors and trigger settings, etc.
I havent tried putting those values myself before as I would have the base map with these settings filled already so not sure how to start. Thanks for your input. If I dont get anything here thats what Im gonna do.
