VW primary trigger
gorinycius
VW primary trigger
Post by gorinycius » Sun Nov 26, 2017 10:21 pm
Hi for everyone,how right setup this one primary trigger
Jan32
Re: VW primary trigger
Post by Jan32 » Tue Nov 28, 2017 8:04 am
it is an normal 60-2 Trigger with Hall sensor.
Angle depends how it is installed on the crankshaft. Is the engine at the picture in OT?
gorinycius
Post by gorinycius » Tue Nov 28, 2017 6:16 pm
Yes,Jan32,is on TDC.Can you write my right setup for primary trigger?(sensor i mark in white)
Post by PSI-Motor » Tue Nov 28, 2017 6:51 pm
Use timing light!
Jan32
Post by Jan32 » Thu Nov 30, 2017 10:30 am
It should be this setting:
first trigger tooth maybe +1 or -1 means 5 or 3. Please check the ignition angle with timing light to be sure.
gorinycius
Post by gorinycius » Thu Nov 30, 2017 5:21 pm
Thanks for replay,Jan32.This weekend try start my project
Paulo11
Post by Paulo11 » Thu Nov 30, 2017 7:11 pm
first trigger tooth maybe +1 or -1 means 5 or 3. Please check the ignition angle with timing light to be sure.Trigger.PNG
I think this isn´t good setting, because teeth are counted from opposite side.
So, the correct setting for me is: First trigger tooth- 33(+-1), rest is good.
Or am I wrong ?
Jan32
Post by Jan32 » Fri Dec 01, 2017 12:00 pm
Paulo, sorry you are wrong :roll:
Trigger wheel is located at clutch side and goes ccw direction!
Paulo11
Post by Paulo11 » Fri Dec 01, 2017 7:26 pm
:oops:
I don´t know that the trigger are on clutch side :oops:
