No WBO Lambda Signal with LSU4.2
Marty
Post by Marty » Sun Jan 07, 2018 10:42 pm
I got no WBO Lambda Signal. I have testet the cables, the seonsor. All ok. The channels of the WBO looks also ok. But I got not Signal in the Monitor/Software.
Do anyone have an idea what could be the problem?
20180107_2135.emulog
Log of WBO Fil
(107.27KiB)Downloaded 88 times
Marty
Re: No WBO Lambda Signal with LSU4.2
Post by Marty » Sat Feb 17, 2018 11:21 am
Wow, so many answers... :shock:
I testet now the cabels again. All OK. With my Innovate LM2 the sensor works also. I testet also a another EMU on the cables. Same situation.
Can it be an problem of the BaseMap? I did used one of this forum, while load it first time, errors comes. Can it be a reason?
Found today this old article: http://forum.ecumaster.com/viewtopic.php?f=19&t=8721
Does EMU have an general problem in production?
Post by PSI-Motor » Sun Feb 18, 2018 5:33 pm
First of all, why do you use the setting "gasoline + 10%"
No nothing wrong with the basemap, the warnings that apear is just that its from a different firmware version.
No its not a general problem in production but it can happend. Nowdays ALL of the ecu:s are tested before shipping.
