Hi to all
One of our drag project cars than we have is a Toyota starlet ep70 with 4age 20v engine with nitrous.
I use a trigger wheel on the crank shaft 36-1 and my first question is how should ignition events should be also injectors events we are using 4 cops from 3sgte st215 (caldina).
also i have some problems when i spray nos the nitrous fuel scale doesn't add the extra fuel!!! i have done all the settings to the emu to see when i spray the engine
here some pics from dragster best time 1/4 mile 13.2 with afr 10:0 due to very big fuel nozzles
TOYOTA 4AGE 20V ITB need some info
- ktsirigotakis
Re: TOYOTA 4AGE 20V ITB need some info
Wire Coils in order 1-1, 2-2 etc... and setup Ignition outputs in Firing order. It's probably 1-3-4-2 for your 4A. Do the same with the injectors. Although you seem to have it running so not sure if that's helpful.
I have no experience with EMU Nitrous control, but I bet if you attach a log and .emu file you may get some answers.
- ktsirigotakis
I have all ready wired up the coils 1-2-3-4 every out put has its own output. I will upload log when we take it for a ride. Its a drag car and its dificalt to go for a ride on road!!!!
Now for the nitrous control i will up load my tune to see what i have done.
Thanks in advance
Thanks in advance
- ktsirigotakis
attached is my emu file this is lets say basic map for 4age 20v i would be very kindly to take a look of my ignition events and injectors events also the nitrous settings at the log seems that emu understand that i am spraying
- 4age 20v with nos dry.emu
- (76.55KiB)Downloaded 99 times
