ignition problem Opel Z20LET
Hello
My engine runs normally when it is cold
when it is hot it is running on only three cylinders under 2,000 rpm
when I go over 2000rpm it is running normally
the ignition module and the spark plugs are new
Good day
Good day
- 10.05.2015 log.emulog
- (1013.24KiB)Downloaded 103 times
- 10.05.2015.emu
- (86.52KiB)Downloaded 117 times
Re: ignition problem Opel Z20LET
Hi, i think you injector sequence is wrong, check Fuelling-Injectors phase
when its cold engine like a bit more fuel but its pig rich when its warm a z20 wil idle at 15 afr all day long but i tend to keep it a little richer but your log is al over the place and some places its well into the 10`s around 1000-1200 rpm hence why its going to run ruff it carnt burn that amount of fuel at such low rpm i wouldnt even put a car running 2 bar of boost under that sort of fueling lean it out under 2k and see if that helps it run a bit better aim for around 14 ish afr and see how you get on
Hello
the engine is running so fat because he has been working on three cylinders
The engine is not working on particulart cylinder or it is random ?
It is always the fourth's. I have also tryed an other ignitionoutput on the ECU.
Maybe to coil or injector are broken ?
coil or injector could also explain the afr as sometimes its ok and other times it looks ok
are you useing the standard z20 coil ?? if so that could be the problem as they arent very good at the best of times
ignition module is new
Injector I have exchanged 3-4
But an unburned Mixture of one cylinder will cause a lean afrpeter1002 wrote:Hello
Hello
have today Engine compression tested 12.9 bar all 4
cable from the ECU to kündmodul I also dipped
and also fat and lean gestelt
still the same problem
is it still on number 4 only ??
have you swaped injector plugs around and altered software to suit that will rule out injectors drivers on ecu
if the problem is still there after that the is either injector , plug or coil
have it all changed still the 4 cylinder
Today I drove 20 min normal then it started again
how old are the plugs ?
its pig rich what ever the problem is
have you a differnt coil pack to try even though yours is new i would change it for another one and try it
i still think it might be a problem with coil pack getting hot and breaking down or dwell is wrong and its over heating
on a side note : best coil pack if you are running wasted spark is the ecotec one one we used them for years with 3 bar of boost and never had a problem with one
the plugs is new
and how is it a setting that I that they stay cold
have you swaped injectors around ( swap 2 with 4 )
what coils do you have ( standard z20let one )
Yes Bosch standart
here I still have the connection diagram
and scope
and scope
- scope_2015514_1447 15.05.2015.emuscp
- (280Bytes)Downloaded 89 times
- 20150514_1523 15.05.2015 log.emulog
- (714.23KiB)Downloaded 77 times
- 15.05.2015 emu.emu
- (86.54KiB)Downloaded 95 times
