Guys, I need your help. It is about installing EMU on 8cylinder 5.5L 32V MB engine. The project is for NA engine in SD mode. It has 60-2 tooth crankshaft mounted TW with (probably) Hall sensor and 4 camshaft 4 tooth trigger wheels, hall synch sensors aswell. We are using the OEM 8 injectors (HI impedance) and 8 VAG "smart" coils.
I can't find in the EMU Manual neither here any information concerning the 8 cyl engines so this board is my only hope.
I guess the EMU set up will be based on a 4 cylinder engine. So, here are my first questions:
1/ How to configure the ECU?
2/ How to wire in 8 injectors (four pairs)? I know every pair should be of two separated by 360 deg cylinders.
3/ How to wire in 8 smart coils (the four pairs of TTL inputs)?
4/ Is it possible to PWM control 4 valves for advancing/retarding the four camshafts?
Endless thanks in advance for your time and support
Regards!
Ivo
