shadowlandz - Posts:20
Launch Control Escort Cosworth
Post
by shadowlandz » Wed Jun 10, 2015 1:36 am
I have the EMU setup on my car, mapped by Oppliger Motorsport in Italy.
There is ALS enabled with a switch but i want to use the launch Control option as well..
Can anybody give me a working example of the LC settings (without using a switch), and without breaking the engine
Thanx in advance!!
Post
by shadowlandz » Wed Jun 10, 2015 1:47 am
Wow thanx!
This is universal then?
I will try and set it up tomorrow morning.
With those screenshot settings it should be safe and working?
Kind regards
samvel - Posts:256
Post
by samvel » Wed Jun 10, 2015 1:04 pm
You need working VSS signal to make it automatic.
RPM, retard depend on Your engine/turbo setup and how much TQ/boost You want to make.
Enrichment depends on EGT and that depends also from retard amount.
Post
by shadowlandz » Wed Jun 10, 2015 11:17 pm
Ehhmmm OK..
What is a working VSS signal? I taught just entering those lines into the EMU setup and save the file..
I just want about 0.5-0.7bar of boost (7psi or something)
So the first thing is, what and how is a working VSS signal?
- Site Admin
Post
by Jadzwin » Wed Jun 10, 2015 11:35 pm
It means your EMU is capable to read vehicle speed (VSS sensor is connected).
Post
by shadowlandz » Thu Jun 11, 2015 12:14 am
Ok great help so far.
Is their a manual or way to have the VSS sensor connected to... what?
We're getting there i see
Thanx for the help allready, i need this stuff working before the weekend!
Post
by shadowlandz » Thu Jun 11, 2015 12:24 pm
How do i know my tuner connected a VSS sensor?
Regards
Karel - Posts:408
Post
by Karel » Thu Jun 11, 2015 2:02 pm
If your EMu know car speed, you will see it.
If not, you need to wire it, if you are not able to feed EMU with car speed, you need to use some switch to activate/deactivate launch control.
Post
by shadowlandz » Fri Jun 12, 2015 12:28 am
I have found out that the ECU cannot read the car speed, so now the next step is to use and wire that switch or as they say VSS signal?
Anybody that can help?
alper
Post
by alper » Sun Jun 14, 2015 10:38 am
use an on off switch on the gear stick or steering wheel if u cant make the VSS work.
Emu Distributor / Tuner
Welshman - Posts:101
Post
by Welshman » Sun Jun 14, 2015 8:58 pm
put a switch on your clutch pedal , adjust it for the bite of the clutch , i used to use this method with an omex launch control , used it to flat shift too
