nissanCA18DET
eugen_troll
I have installed oil press sensor.
But my oil press log ist very irregularly.
It is ok?
Maybe need a pressure Software filter for oil press table?
Big THX
It is ok?
Big THX
- ca18detsuper98advence.emu
- (85.1KiB)Downloaded 130 times
- 20150412_1910.emulog
- (825.49KiB)Downloaded 130 times
Re: Oil Press ok? CA18DET
had a very quick look and it looks ok from what i could see
there is a lot of noise in the signal possibly caused by engine vibration or something like that, but nothing to be too worried about.
eugen_troll
Re: Nissan CA18DET
Have a Laging by normal driving.
In my Log by Time 3:59-4:01.
Any Ideas?
My log.
Any Ideas?
My log.
- 20150526_1003.emulog
- (440.33KiB)Downloaded 169 times
eugen_troll
Re: nissanCA18DET
Hello
My Batterie Voltage has a 18volt at high RPM is this a Problem?
Next problem ist bad dyno log.
Whats a problem on my car?
- 20150606_1930.emulog
- (1.06MiB)Downloaded 121 times
Re: nissanCA18DET
Use higher filter value for dyno.
For battery voltage you should fix your alternator (voltage regulator).
eugen_troll
Re: nissanCA18DET
I missing one option.
I set a Idle valve PWM to 50%DC for my WOT, this setting is active if my tps over idle.
but i find this option anymore?
Maybe i blind or this option not more active in new Software?
I hope you understand my.
Best Regards eugen
Best Regards eugen
- Unbenannt.JPG (30.07KiB)Viewed 9149 times
Re: nissanCA18DET
Idle RPM ref is called 2d map responsible for dc out of idle
eugen_troll
Re: nissanCA18DET
Very big THX.gregpe wrote:Idle RPM ref is called 2d map responsible for dc out of idle
eugen_troll
Re: nissanCA18DET
I have a next problem.
By crusing about 2000-3000rpm have a bug.
See my log.
Anyone a ideas?
See my log.
Anyone a ideas?
- 20150718_2157.emulog
- (984.39KiB)Downloaded 100 times
- bug.JPG (31.72KiB)Viewed 9130 times
Re: nissanCA18DET
look like wiring problem shorting 5v to sensor ground or to ground you looking all reading tps voltage analogue and triggers... check your wiring
Re: nissanCA18DET
Was the engine worked correctly ? Looks like communication problem
eugen_troll wrote:I have a next problem.
See my log.
Anyone a ideas?
eugen_troll
Re: nissanCA18DET
Engine works correct, but over this bug 1-2 second is engine off. Sometimes is Tacho over this bug also dead.Jadzwin wrote:Was the engine worked correctly ? Looks like communication problem
See my log.
Anyone a ideas?
Enging going thereafter not in Afterstart.
This bug i watching only in crusing speed, never WOT.
Without a computer is the same.Looks like communication problem
thx
Re: nissanCA18DET
I will investigate it. What FV do you use ?
eugen_troll
Re: nissanCA18DET
I use 1.135.
In old software was same.
