Bluetooth help..
JermMer
Bluetooth help..
Post by JermMer » Fri Jul 31, 2015 6:33 am
Guys having troubles with my bluetooth app...
Downloaded the app onto android device and I can get it to pair with the ecu but all values are showing zero 0..
What am I doing wrong?
Wuniek
Re: Bluetooth help..
Post by Wuniek » Fri Jul 31, 2015 8:03 am
JermMer wrote:Guys having troubles with my bluetooth app...
did you set proper protocol in EMU options ?
external port.jpg (26.9KiB)Viewed 9296 times
JermMer
Post by JermMer » Fri Jul 31, 2015 10:30 am
Can you be more descriptive please?
What protocole do I need to select?
There is a few there in that pic you posted
roquete
Post by roquete » Fri Jul 31, 2015 11:25 am
Ecumaster serial protocol
JermMer
Post by JermMer » Fri Jul 31, 2015 11:46 am
So just select that and pair the android tablet to the ECU punch in code 1234 and it should all work?
Thanks in advance
JermMer
Post by JermMer » Thu Aug 06, 2015 6:23 am
Still can't get this thing to work..
Selecting under the device drop down menu..
ECUMASTER serial protocol
Have both box ticked for "send EMU data over CAN-Bus" and "send data to BTCAN module"
I can see the emu on my android tablet but when I click on it it reads "Connection failed. EMU NOY FOUND"
What is wrong with this thing?
Side not maybe include instructions in the packet.
Wuniek
Post by Wuniek » Thu Aug 06, 2015 8:36 am
are you saving your setup to ECU ?
i never had problem with BT module, alternatively you can try VEMS Display with AIM dashboard protocol
JermMer
Post by JermMer » Thu Aug 06, 2015 8:50 am
Yup making changes then hitting " Make permanent "
Wuniek
Post by Wuniek » Thu Aug 06, 2015 9:24 am
JermMer wrote:Yup making changes then hitting " Make permanent "
hmm i don`t know where and how far is your emu device with bt module, for example mine is in engine bay and my connectivity is reduced to area close to windshield...
JermMer
Post by JermMer » Thu Aug 06, 2015 9:33 am
Emu is under the steering wheel above my knees.. Bluetooth dongle is obviously right Bennett steering wheel and the tablet is in my lap.. Be lucky to have 30cm distance..
The thing is I get a solid light on the dongle so I guess that means it's connecting?
Wuniek
Post by Wuniek » Thu Aug 06, 2015 9:37 am
ok my last try, you are using some kind of Lenovo device
JermMer
Post by JermMer » Thu Aug 06, 2015 11:18 am
Nope it's not Lenovo but it's just a cheap android tablet..
Tell me about your theory though as it may still work
Wuniek
Post by Wuniek » Thu Aug 06, 2015 11:37 am
there was some kind of issue with bluetooth driver on some Lenovos...
maybe try on smart phone im using it on Samsung Galxy S2 and S5 and two Xperia without any issue
it always can be faulty hardware :( but you will not have problems with replacement or repair
JermMer
Post by JermMer » Thu Aug 06, 2015 11:49 am
Well I have tried two different tablets but sadly I don't haveva android phone..
Does anyone else have some input?
Surely mr ecumaster himself monitors this forum
Welshman
Post by Welshman » Thu Aug 06, 2015 1:31 pm
mine works fine
i have ECUMASTER serial protocol checked
nothing else though
MK2MR2
Post by MK2MR2 » Sat Aug 15, 2015 10:38 pm
Where is that menu/setting located? I can't find that anywhere. I am on software 1.134 Exp 1
derOJ
Post by derOJ » Mon Aug 17, 2015 12:10 pm
Is it somehow poosible to use the bluetooth connection instead of the USB connection to program the EMU?
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Mon Aug 17, 2015 3:35 pm
No, You can't.
derOJ
Post by derOJ » Mon Aug 17, 2015 5:10 pm
hmm...would be a nice Feature :mrgreen:
EMU not found
Post by RHD » Wed Aug 19, 2015 7:00 am
I have tried everything i still get the same message "Connection failed Emu not found" it appears to pair up to the bluetooth no problem just do data is transferred
same deal when i try my android cellphone... occasionally it actually opens the dash but still no data transfer everything reads ZERO
