Rolling Anti-Lag
shadowlandz
Rolling Anti-Lag
Post by shadowlandz » Thu Sep 17, 2015 2:31 pm
I do lot of streetraces here and we always start with rolling starts like in 2nd or 3rd gear.
I see the rolling anti-lag feature so i want it because i think it will give me a big benefit!!
Can anybody help me get this on my Escort Cosworth?
Cheers!!
ktsirigotakis
Re: Rolling Anti-Lag
Post by ktsirigotakis » Fri Sep 18, 2015 12:17 pm
Hi m8 here in greece we do the same and i have engage with a button the PIT LIMITER at 60km/h for me it look that work fine you can tray it. the car locks at 60km/h and wont go farther.
Post by Jadzwin » Wed Oct 14, 2015 8:16 pm
You need just connect button to EMU analog input that will be used to activate the rolling antilag strategy.
Then setup Boost target to desired value. It should work, eventually tune the kP parameter
shadowlandz
Post by shadowlandz » Wed Dec 30, 2015 11:20 am
Hello
I have a "MUX switch" that activates my ALS.
Can i use this to active rolling antilag?
What parameters can i set for this:
I want the turbo to make almost 1bar when i activate this button
Boostcontrol kp
Sparkcut kp
max spark cut
max ign retard
what is safe?
Cheers for the help
shadowlandz
Post by shadowlandz » Wed Jan 06, 2016 10:44 am
Nobody can help me get this set up? (parameters for testing)
Post by Jadzwin » Tue Jan 19, 2016 7:49 pm
Set enable option.
For input select the MUX switch that you are using (1,2 or 3).
Make test on the road and send here the log. Then I will be able to tell you how to adjust parameters
