Hi Guys
New to this forum.
I just installed a EMU in my car instead of my previously ProEfi 128 (Excellent EMS but no support over here in Denmark)
So i got the EMU recommended by several tuners.
My Car is up and running now, but it dont feel quite right, So i was thinking if any of you guys in here, have a map for a 2jzgte they would share, then i will try that out.
/ Danny
2JZGTE map
2JZGTE Powered BMW E39 540i (Daily driver) Build engine ECU Master EMU Flex Fuel FID1400 722.6 / NAG1 auto(5 speed) FSR cast manifold PT6466 272 cams
Re: 2JZGTE map
Rather than dumping another unknown map in the car, can you post your current map and log so that we can give you input on what changes should be made?
Re: 2JZGTE map
Hejsa
Prøv ellers og kontakt KK Autoteknik
Jeg har et map til at ligge til en 2jz gte vvti hvis det er
Flemming Rosborg
RiiS DRiFT
Follow on Facebook! facebook.com/riisdrift
RiiS DRiFT
Re: 2JZGTE map
Hi Zach
here is the map
Hej Flemming
Det må du gerne sende til mig hvis det er muligt.
/ Danny
here is the map
Hej Flemming
/ Danny
- 20151004_1054.emulog
- Log
- (451.68KiB)Downloaded 106 times
- Fernandez_001.emu
- Map
- (88KiB)Downloaded 150 times
Re: 2JZGTE map
before you get any further you should update to the latest firmware test version then select Advanced Lambda fueling strategy then you must fill out the charge temp table and target fuel table in lambda its a much better fueling method and then you can use autotune etc.
also try smoothing your map!! it should all slope up to the right, theres placed where lower map value has higher VE !!!! its no wonder its bucking and surging
I actually just started supra install today so might have something in a week or so
Re: 2JZGTE map
Ok thanks
i will try and get it updated to the latest firmware.
/ Danny
Ok thanks
/ Danny
Re: 2JZGTE map
Har du noget email/facebook eller andet?
Flemming Rosborg
RiiS DRiFT
RiiS DRiFT
Re: 2JZGTE map
ja du får den her: Fernandez@live.dk
