Cant rotate above ~6600 rpm
DT-GT42
Post by DT-GT42 » Wed Dec 16, 2015 10:24 pm
Hello
I have a problem with my vr6 engine.
i think i have problems with my trigger signal because when i drive on the railway sometime lost the signal.
and a other problem is my engine can not rotate above 6600 rpm.
my rpm limiter and fuel cut etc is 7300.
maybe anoyone has so idea , why the engine cant rotate to the rpm limiter.
Greetz
log1.emulog
(1.96MiB)Downloaded 123 times
Jan32
Re: Cant rotate above ~6600 rpm
Post by Jan32 » Wed Dec 16, 2015 11:07 pm
In your log are a lot of tuning faults to see.
Dwell time is wrong when you use the wasted spark VR6 ignition module.
Warmup enrichment at CLT of 82°C and IAT correction of 22°C ???
Your ignition angle at low loads are everytime nearly the same and very low.
Please make a scope of your trigger signals and post config file here.
DT-GT42
Post by DT-GT42 » Wed Dec 16, 2015 11:49 pm
Sorry but i dont understand..
What do you mean with the warmup enrichment 82 c. And ias correction 22 ?
DT-GT42
Post by DT-GT42 » Thu Dec 17, 2015 12:07 am
here is mein config file and scope
scope_20151216_2012.emuscp
(248Bytes)Downloaded 119 times
file.emu
(96.14KiB)Downloaded 109 times
Welshman
Post by Welshman » Wed Dec 30, 2015 12:14 am
ign map looks back to front to me , 45 degree at high boost and rev ?
Post by Jadzwin » Wed Dec 30, 2015 12:54 am
It is not a trigger problem. There are no evidence of any trigger issues.
What is your spark plug gap ? Maybe you should increase dwell time ?
What is lambda / AFR ? On log there is 8. Eventually what fuel do you use ?
DT-GT42
Post by DT-GT42 » Wed Dec 30, 2015 2:19 pm
Hello I found the problem why not turn higher . with gear sensor input I have an analog cable lock attached , but it was not active (see picture) .
When I put this out , has all works as it should .
