Hi, i've installed the new version of the software 1.062 but when i connect the ecu, automatically the software 1.016 was open. What is the problem?
thank you
New Software
Re: New Software
you have to upgrade the firmware of the EMU itself. Seen on the picture or in the manual
Re: New Software
Thank you. I've another question: When the TPS is 0% anche the pressure in intake manifold is 20-30kpa the lambda do not analize exhaust gas and the car "bang bang".
Ve table and ignition table is ok. (75% and 20-30 degree).
Cut off is disactive. I have not ideas.
Thank you
Thank you
Re: New Software
If the mixture is too rich the lambda switch from rich to lean. Maybe that is the problem. 75% is a very high value for idle.
