fletch83 - Posts:8
2jz Idle
Post
by fletch83 » Wed Mar 02, 2016 10:00 am
Hi All,
Trying to get my idle stable on my 2jz and tried all i can think of so far. Im using open loop for now till i get it stable then ill setup closed loop. It goes up and down a couple hundred rpm. Engine has 264 cams, 1000cc injectors, 43psi pressure.
Is this normal for this engine? Do i need to set it up on closed loop to get a stable idle?
Attached is a log file
Thanks for all help in advance
- 20160302_1806.emulog
- (63.36KiB)Downloaded 101 times
fletch83 - Posts:8
Post
by fletch83 » Wed Mar 02, 2016 10:06 am
Attached is my map
- 2jzgte.emu
- (77.97KiB)Downloaded 114 times
ihiryu - Posts:237
Post
by ihiryu » Wed Mar 02, 2016 8:31 pm
I haven't looked at your MAP, but how is your timing table?
fletch83 - Posts:8
Post
by fletch83 » Wed Mar 02, 2016 10:01 pm
Ive got my idle area on 8 degrees atm around idle with a lip just below it at 10 degrees. If i use higher timing it gets even more unstable.
ihiryu - Posts:237
Post
by ihiryu » Fri Mar 04, 2016 1:19 am
Try 15 degrees, and check your fuel map.
And did you check that your mechanical timing matches your ecu timing?
ihiryu - Posts:237
Post
by ihiryu » Sun Mar 13, 2016 2:46 am
Agreed, I don't allow EGO correction until 1300 until we get to 100 KPa
fletch83 - Posts:8
Post
by fletch83 » Sun Mar 27, 2016 2:16 am
I got the idle better but not perfect at 900 using 15 degrees around idle and a lip under it at about 18 degrees. Im going to degree the cams this week. I think that may help. (Shoould have done this before).
The engine seems to idle a bit smoother with the afr's are in the 13's. Has a little pop everynow and then when at around 14.7. It has to pass emissions tests here for rego so i need it at 14.7.
Thanks for all your help guys!
