best trigger disc pattern
Why i can see 611.44° of CAM 1 angle related to crank it make no sense (refer to first picture above) where should i position reference tooth edge to have something between 0-360?
Re: best trigger disc pattern
no no, the working cycle on 4 stroked engine is 720°
ony every 2 full revolution you have one working cycle
So cam 1 angle will allways be in range of 360 to 720° ?
And its even more interesting then that, because value in case on picture is actualy negative so -611.44° so it seems to me that range can be -720° to +720°
Ok so i look thru logs and on subaru ej20 i found -836° on nissan sr20 i have -723° on some ford i have -677° and -825° on mx5, so it seems that values are allways negative and higher then 360. Ej20 and mx5 is wery interesting, because its offset cannot be compensated with VVT setting "cam1offset" because this value can be only in range from 0 to 800
Any ideas around this?
