1jz vvti pin out please help!!
pink24
Post by pink24 » Sun Sep 28, 2014 1:42 pm
hi i have fitted a 1jz vvti from a jzx 100 into a r33. i am struggling to find the correct pin out diagram so i can wire the needed wires to the ecu master plugs.help on finding the correct diagrams would be much appreciated. please help!!
odd boy
Re: 1jz vvti pin out please help!!
Post by odd boy » Fri Oct 10, 2014 1:41 am
can you upload a picture of the ecu, the sticker and the connector at the ecu side
pink24
Post by pink24 » Mon Oct 13, 2014 4:53 pm
Hi mate . thanks for your reply. I have found one of the only correct pin out diagrams for the jzx100 and I will be posting it this evening to help others doing the same conversion . I will also have a few questions for forum users . Thanks.
samvel
Post by samvel » Fri Jan 30, 2015 8:52 pm
Hello. Can You please post this wiring diagram of VVTi 1JZ
Edit: No need, have found already.
