oil temperature sensor for stock gauge and EMU?
Posted: Tue Jan 12, 2016 9:48 pm
by Olli.D
I like tuo use the stock sensor, what is already connected with the stock gauge.
Over the bandwide 20-100 degrees, i can read 6 - 8 Volt.
The EMU software only allowes 0 - 5V. When i try to switch to 8V, it goes back to 5V max.
The resistance of the EMU input 1 is about 980KOhm. Is it ok, if i just take a resistor of same (test +/-) Ohm in row?
So i would read about 3-4 Volt...
The measurement of the original gauge seems not to be irritated, that works with ca. 250 Ohm.
Is that practicable, or would you recommend another way?
Cheers, Olli
Re: oil temperature sensor for stock gauge and EMU?
Posted: Wed Jan 13, 2016 1:32 am
you may want to connect 2 resistors about 1k from the gauge Op in series to ground and connect the EMU to the join between the 2 resistors thus forming a voltage split. you can scale the range by altering the size of one of the resistors etc.
Posted: Wed Jan 13, 2016 9:22 pm
by Karel
any resistence from sensor to ground will affect the reading ............ i dont recommend it
if ..... i would use much bigger resostros for voltage divider, like 10k and above
Posted: Sun Jan 17, 2016 9:12 pm
by Olli.D
It is tested out today.
One part of the voltage splitter is the EMU herself with about 980KOhm, the second resistor what is built in row now, has 500KOhm.
With 18°C i get 4,6V and with 120°C 1,8V.
That works really fine!
Just need to switch the OilCooler fan by EMU.
That does not affect the readings of the stock gauge. Or better: you cannot see a difference.
Thank you for your input!
