Which is the best place to gorund the shields of the VR sensors? B17?
Which is the best place to ground VR sensors shields?
Re: Which is the best place to ground VR sensors shields?
B17 not B18Omibi wrote:Hi,
OOps got in a hurry and mis-typed.
ATS_Scott wrote:B17 not B18Omibi wrote:Hi,
I like to ground everything direct to the battery -ve using as many separate wires as possible. Only CLT ,air temp to the sensor ground on the ECU
SHIELDS not grounds!... can be earthed anywhere on the chassis but ONLY at one end of the shield
Yes shields as well straight to the battery neg. Only wires I put to chassis or engine block would be coil grounds
