Hi I am going to fit a idle control valve and would like to know the best one for EMU to control, any recommendations?
Idle control valve recommendation
Re: Idle control valve recommendation
Basic bosch 2-pin idle valve motor. You have to use only one PWM output for controlling. It is used at least in older BMWs and Opels. It has two 15-20mm? hose connetors, so it is very convient to install. Cheap part, about 20-30€ for used one.
It is not the best, but cheap and works well.
Ideal, thanks, just ot a 2 pin bosch of a saab at the scrap yard for £5, after a bit of DC fiddling it seems to work quite well, just need to tidy the plumbing but its nice and simple, thanks
